DIAdem
Programatic control of report scales
Is it possible to have programatic control of the graph scaling?
Second, would it be possible to link to a widget on the report like a slidebar
to I can zoom to specific 'planes' in a 3D graph?
Thanx.
(3,362 Views)
You can programmatically set the report scales by opening the report axis object, i.e. 2dAxis system
Dim Xscale, Yscale
Xscale=Array(-0.1,0.4,-0.1,0.05,0)
Yscale=Array(-50,10,-50,10,4)
Call GRAPHObjOpen("2DAxis1")
            Call GRAPHObjOpen("2DXAxis1_1")
            D2AXISXBEGIN = Xscale(0)
            D2AXISXEND = Xscale(1)
            D2AXISXORIGIN = Xscale(2)
            D2AXISXTICK = Xscale(3)
            D2AXISXMINITICK = Xscale(4)
            D2AxisXFormat=GetdddFormat(D2AXISXTICK)
        Call GRAPHObjClose("2DXAxis1_1")
        Call GRAPHObjOpen("2DYAxis1_1")
            D2AXISYBEGIN = Yscale(0)
            D2AXISYEND = Yscale(1)
            D2AXISYORIGIN = Yscale(2)
            D2AXISYTICK = Yscale(3)
            D2AXISYMINITICK = Yscale(4)
            D2AxisYFormat=GetdddFormat(D2AXISYTICK)
        Call GRAPHObjClose("2DYAxis1_1")
    Call GRAPHObjClose("2DAxis1")
If you put the larger section in a user command file then you can change the scales programmatically very cleanly, and send the array contents from a script.
As far as a slider bar, this sounds like you should be using the VIEW module.  Use the VIEW module to view and cursor through your data, use the REPORT module to print.
(3,340 Views)
