DIAdem
Property Maximum for Channel doesn't work
I have a problem on the Maximum-Property for Data-Channels.
So if I create a new Channel and want to get the maximum of the new Channel like this:
Dim Grp: Set Grp =  data.Root.ChannelGroups.Add("Group_1")
Dim Channel1: Set Channel1 = Grp.Channels.Add("Channel1",DataTypeChnFloat64)
'Fill Channel
Dim i
for i = 1 to 10
   Channel1(i) = i
'Get Maximum
Dim ChnMax
ChnMax = Channel1.Maximum
LogfileWrite "ChnMax: " & ChnMax    'does not work: ChnMax = Null
'However:
LogfileWrite "Channel1(5)= " & Channel1(5)
The result is Null - however, if I want to get a specific value of the Channel (like the 5th value), it works.
What is the problem here? Also in the data-portal the right value for the maximum will show up:
 Thanks in advanced for your help!
(1,696 Views)
Accepted by MaT_305
Hello MaT_305,
Which DIAdem version do you use?
With the command "ChnCharacter" you can calculate the chracteristics of a channel.
'Fill Channel
Dim i
for i = 1 to 10
   Channel1(i) = i
call ChnCharacter(Channel1)
'Get Maximum
Dim ChnMax
'However:
Greetings
Walter
(1,652 Views)
Hello Walter,
Thank you for your solution.
I´m using Diadem 2018.
So do I always have to "update" the created channel with the command 'ChnCharacter' in order to get min/max of a Channel?
(1,648 Views)
Hello MaT_305,
Ideally, these characteristics would be calculated each time the value changes. We will have a look at this, and as long as it does not work this way, the ChnCharacter() command is a good workaround.
Greetings
Walter
(1,639 Views)
