DIAdem
REPORT - n systems plots - Curve Related - Sub systems
When I create a graph in VIEW, I can plot several channels in the same subsystem using the "curve related" option. However when I transfer to REPORT, all the curves are in different systems and I can't find a way to put them together again.
Is there a way (with a script?) to create display options to add subsystems (in the 'Axis Position' tab) and then select the right system for each curve (in the 'Curve List' tab)?
Any help is appreciated.
Pierre
(3,722 Views)
Hey Pierre-Damien,
I am unclear on what your problem is. From what I understand, in VIEW you set custom scales using the Curve Related scaling of your 2D Axis System. You try to export that view into REPORT but all your curves now appear on different axis systems.
I did that test and it works fine for me on DIAdem 2017.
What version do you have. Can you share your TDV and TDR so that we can see what you observe ?
CLAMaxime -- Kudos are a great way to say thank you
(3,708 Views)
I have attached some screenshots
1: n- y systems in VIEW
2: Select multi-y systems graph in REPORT
3: Plot all the curves
4: Open the editor by double clicking on graph in REPORT
5: Select the appropriate Y system
6: done
I was not sure if that was what you meant though
(3,656 Views)
Maxime,
I'm using DIAdem 2017.
I attached some screenshots to help describe the problem.
01 : n-systems in view with different channels sharing the same systems.
Here the 'Minimum temperature' channels are together, the 'Maximum temperature' channels are together as well in an other system and 'Precipitation' is in its own system.
02 : I use the 'Transfer to REPORT' function.
03 : All the channels are now in different systems
04 : I can't create sub-system 'Y2', 'Y3'... as I would be able to with a n-axis system.
I hope this makes my request clearer.
Pierre-Damien
(3,653 Views)
I see. Can you share your data so that I can make some tests with it please ?
(3,651 Views)
I can't share the actual data, for the example I used the data in example call 'WEATHER'.
(3,641 Views)
Thanks. Unfortunately after playing around with the data I cannot seem to get anywhere close to what you are trying to achieve. I guess that you would have to have 3 different areas on your VIEW and then transfer it to REPORT, thus creating 3 different axis system on the report.
Maybe someone else has a better idea ?
(3,627 Views)
