DIAdem
RadioButton
How do I access the RadioButton's?
In every method like "EventChange" I get the Error that this method supported.
Thomas
Message 1 of 9
(6,432 Views)
Hello Thomas!
The value is in the Value property of the radio button group. You can define the value for every button in the ListItems editor.
Example:
Sub RadioButton1_EventChange()
Dim This : Set This = RadioButton1
MsgBox RadioButton1.Value
End Sub
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Message 2 of 9
(6,426 Views)
Can you get those informations by the help?
Thomas
Message 3 of 9
(6,428 Views)
Hello Thomas!
In this case: Not really! (DIAdem 9.1)
There is some information for this topic in the help but it is more able to confuse then to help. I have heard that this will be better in the DIAdem 10 help.
My way was a combination of knowledge and combinatorics. Just have a look on the properties list and try to change the settings in the SUD editor. You will see the result without running the dialog.
Matthias
Matthias Alleweldt
Twigeater?
Message 4 of 9
(6,415 Views)
I like to change the name of the Items from a RadioButton. I did try some stuff but it never works.
RadioButton3.Items(1).Name
How do I access the Name of each Item?
Thomas
Message 5 of 9
(6,356 Views)
Hello Thomas!
Try RadioButton3.Items(1).Text and before you ask: Found by trial and error.
Have fun with SUD ;-)))
Matthias
Matthias Alleweldt
Twigeater?
Message 6 of 9
(6,350 Views)
Thanks Matthias
Message 7 of 9
(6,348 Views)
Reviving an old thread here, but I'm looking for some information on using Radio Buttons.  Most specifically how change the value of a radio button when another is clicked (only one selected at a time) and then also how to use the current value of a radio button in an If-statement.
Message 8 of 9
(5,561 Views)
Hello!
In SUD RadioButtons are grouped. This group has one property 'Value'. Possible values of 'Value' are defined while adding buttons via the 'ListItems' property. You can read or write 'Value' whenever you want.
Hope this helps a little bit. Otherwise feel free to ask
Matthias
Matthias Alleweldt
Twigeater?
Message 9 of 9
(5,525 Views)
