DIAdem
Checkbox If-Statement
Simple question here, but I can't seem to find the answer to it.  I want to simply run a section of code if a checkbox is checked, something like this:
If CheckBox1.Value = 1 Then
     'Code Here
End If
I want to place this code within a DIAdem autosequence, but the object is not being recognized within my script.  Any help would be appreciated
(4,169 Views)
Hello!
You have to understand that SUD dialog objects are not available in DIAdem scripts. If you want to use the state in a DIAdem script and not in the SUD script you have to connect the checkbox to a DIAdem variable or save the state in a variable.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,147 Views)
Thanks, Matthias.  I thought this might be the case.
(4,142 Views)
