DIAdem
.daq files
Does anyone know if it is possible to import *.daq files generated by The Mathworks Data Acquisition Toolbox, into DIAdem?
(3,919 Views)
I am not aware of any existing dataplugin which supports this file format. To my knowledge, TMW never documented the format. Instead they recommend to convert it to something else when you want to read it outside MATLAB.
There is an example on ni.com "Reading TDM/TDMS Files with The MathWorks, Inc. MATLAB® Software" which shows how to write a TDM file from MATLAB. Could you consider this as an alternative ?
Andreas
(3,910 Views)
