DIAdem
Report Diadem Display modes
Hello
I' m using DIAdem 11.1 to produce a report,  but the output ain't quite what i'm expecting.
please see the following image:
On the left side the graphic shown in red isn't the same as the preview (on the lower right side).
I know a can customize the Display mode, but none of those options produce a graphic exactly the same as the preview.
Thanks in advance, good work.
(3,806 Views)
Accepted by AlexandreHSCastro
Hello!
Assuming your time channel is not equidistant: The reason is that in report the time is the X axis values and in the preview the sample index is the X axis values (implicit). Both displays are right in their way. From an engeneering point of view the report is more meaningful to me. AFAIK it is not possible to customize the X axis in the preview.
Matthias
Message Edited by Twigeater on 05-18-2010 04:26 PM
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,800 Views)
