DIAdem
Run Python script
I have Win 7 64 bit
Python 3.8 or Python 3.7
Diadem 2020 SP1.
I write Script, and try to run , but
How can I solve this problem.
(2,911 Views)
Accepted by Spiky
Hello Spiky,
If you have installed, you own Python 64 Bit version – which needs to be supported by DIAdem – then it is also necessary to have the Python-Modul PyWin32 installed. (If not, use PIP installation for it.)
Here is a list of installed and supported Python versions.
DIAdem supports only 64 Bit Python.
DIAdem version
Installed Python base package version
Supported Python version
2020
3.7
3.6
2020 SP1
3.7
3.6
2021
3.8
3.6, 3.7, 3.9
2021 SP1
3.8
3.6, 3.7, 3.9
Greetings
Walter
(2,876 Views)
I install
python-3.8.10-amd64
python-3.7.9-amd64
(2,867 Views)
Accepted by Spiky
Did you installe the the Python-Modul PyWin32 for version 3.7?
(2,863 Views)
how can i install Python-Modul PyWin32 for version 3.7 without internet on ps?
(2,857 Views)
Accepted by Spiky
Hi Spiky,
This is a general Python installation question (not a DIAdem problem).
On the internet you find for example these links for this topic:
https://stackoverflow.com/questions/67365737/trying-to-install-python-librariespywin32-on-system-hav...
https://pypi.org/project/pywin32/
Greetings
Walter
(2,849 Views)
(2,844 Views)
