DIAdem
SI formatted data on LabVIEW Graph does not export correctly to Diadem
FYI if you have a graph in LabVIEW (2012) with the x-axis formatted in SI units it does not export correctly Diadem (2012) - the scaling factor is ignored!  To be clear, this is when you right click on on a graph and select "Export Data to Diadem".
Tis must be an easy bug to fix?
(5,321 Views)
Hi Steve
Thanks for posting.
I've just had a go at replicating this and I'm not able to see the issue.
Could you please take a look at the screenshot I've attached and let me know what I'm missing to replicate?
I'm running LabVIEW 2012 12.0.3 and DIAdem 12.0.0.4911
Kind Regards
Chris
Chris | Applications Engineer NIUK
(5,235 Views)
