DIAdem
SUD Control OnEvents
I would like to kniw how to refresh a control while I am executing an script. I have already tried with the Refresh method.
Attached there is SUD that shows my problem
Thank you in advance
(5,376 Views)
Hi dslemusp,
Are you calling the SUDialog non-modally or modally-- put another way, are you using SudDlgShow() or SudDlgCreat() to call the dialog?
Is the "script" you're referring to the script that calls the SudDialog, some script code running in the dialog, or is it supposed to be a script running in parallel with the SUdialog?
Brad Turpin
DIAdem Product Support Engineer
(5,330 Views)
I have tried to load the SUD modal and non-modal, but It doesnt work. The Control I am trying to refresh gets freezed and only shows the final value once the script is finished.
The Script I am refering is the one which the SUD executes once you press a button (In this Example the Exe Button). Actually I call a function registered in the user command. But I also made the test pasting the function inside the SUD and It has the same behavior.
(5,323 Views)
Accepted by topic author dslemusp
Hi dslemusp,
I talked to R&D about this, and the short answer is that the Windows operating system technology the SUDialogs are using blocks the display you're hoping for.  The best workaround we could come up with is a non-modal pop up dialog:
Sub Button1_EventClick(ByRef This) 'Created Event Handler
  Report.NewLayout
  Dim i, Txt
  For i = 1 to 5
    Txt = "Progress " & i*100/50 & "%"
    Call MsgBoxDisp(Txt, "MB_NOBUTTON", "MsgTypeNote", 0, 0, 1)
    Pause(2)
  Call MsgBoxCancel
  Status.Text = "Done"
End Sub
Another option would be to control the DIAdem progress bar in the lower right hand corner of DIAdem.
Brad Turpin
(5,279 Views)
