DIAdem
SUD GetArgument Error: Object Required
Hello All,
This is my first serious attempt at creating an SUD dialog box (modal). I did things according to the manual, but get the following error:
Dialog Editor (SUD)
Error in <20121112_M1545_postexfacto_DDMcomp.SUD,Dlg1> (Line: 14,Column: 2):
SUD event context:
  Dialog_EventInitialize(...)
Objekt erforderlich: 'This.GetArgument()'
OK
 The underlying code is this:
Sub Dialog_EventInitialize(ByRef This) 'Created Event Handler
	Set parameterList = This.GetArgument()
	Call File1Input.RunInitialize
	Call File2Input.RunInitialize
	Call ResultFileInput.RunInitialize
End Sub
 It is the second line of the Sub that generates the error. I would be very grateful if you could tell me what I am doing wrong.
Leo Zschokke
Test Engineer C-EPS
ThyssenKrupp Presta AG
(6,523 Views)
Accepted by topic author ledz
Hi Leo,
I assume that you didn't use the object "parameterList" as parameter in the command line which calls the dialog in your script.
call SUDDlgShow("DialogName", CurrentScriptPath & "SUDFileName", ObjectName)
Greetings
Walter
(6,521 Views)
I did pass an argument, but it was an array (which did not work). I now created a class with three public properties, each of which should be returned by the dialog box.
Class M1545_TTRcomp_parameters
	Public file1Path, file2Path, resultFile
End Class
 The properties are set by filling three text fields in the dialog, which are read when the OK button is clicked:
Sub OK_EventClick(ByRef This) 'Created Event Handler
	parameterList.file1Path = File1Input.GetSelectedText
	parameterList.file2Path = File2Input.GetSelectedText
	parameterList.resultFile = ResultFileInput.GetSelectedText
	Call Dialog.OK
End Sub
 When I now call the dialog box and display each property, it shows that only the first contains anything:
Dim testObject
Set testObject = New M1545_TTRcomp_parameters
If SUDDlgShow("Dlg1","20121112_M1545_postexfacto_DDMcomp.SUD",testObject) = "IDOk" Then
	Call MsgBoxDisp("Success!")
	call MsgBoxDisp(testObject.file1Path)
	Call MsgBoxDisp(testObject.file2Path)
	Call MsgBoxDisp(testObject.resultFile)
Else
	Call MsgBoxDisp("Failure.")
End If
 So obviously it works to some extent, but I am preventing all input to get through.
Leo Zschokke
Test Engineer C-EPS
(6,516 Views)
The problem has been solved; I used "GetSelectedText" to retrieve the contents of the text input boxes, instead of "Text". It works now; thank you for your help, Walter!
Leo Zschokke
Test Engineer C-EPS
(6,511 Views)
