DIAdem
execute script without closind dialogbox
I woud like to execute my main script.vbs
And in the same time keep a dialog box open with one button changing a global variable.
how can i do that?
fmanuel
(5,590 Views)
Hi fmanuel
Is your global variable declared in the main script??. If it so, you should create a SUD which calls the main script in the Initialize Event, and modify the global variable using the events for the button control. Once you have the SUD you should call it using the Call SUDDlgShow function.
Cheers
(5,586 Views)
How should i call the main script?
(5,578 Views)
Hi frmanuel,
remember to call a not modal dialog so that the Mainb script can run further while keeping the SUD Dialog opened.
Command: SUDDlgCreate
http://zone.ni.com/reference/en-XX/help/370859J-01/comoff/suddlgcreate/
Best regard
Andre
(5,565 Views)
Thanks for help, i did it this way:
If NothingisSudNonModalDlgLst("Dlg2") Then
   Set profile_search_dialog_box = SUDDlgCreate("Dlg2",MyFolders(1)&"profile_search_dialog_box.SUD",NULL)
Else
   Set profile_search_dialog_box = SudNonModalDlgLst("Dlg2")
End If
      Call profile_search_dialog_box.Show
But now I can not act anymore on my buttons.
I did use:
Call InteractionOn
Then my Dialogbox became active and my script stop working
How can I have both: Script.vbs runníng and in the same time buttons working?
fmanuel
(5,551 Views)
Unfortunately not.
VBScript doesn't seem to embrace a straight forward notion of multithreading, so there will be no way to execute these tasks (main script and dialog) in parallel.
Andrea
(5,547 Views)
