DIAdem
SUD-dialog should wait for Labview VI has finished
Diadem 10.1
Labview 7.1
A compiled Labview VI should start from a SUD-Dialog. Then, the Dialog should wait for VI has finished. I don't find a solution. There are 2 possible ways:
1. Run VI as parallel task:
Call ExtProgram(Deskdrv&"\Labview\TestVI.exe")
While (VI_is_running)
    pause(1)
Wend
How to write write function "VI_is_running"?
2. Run VI modal:
Example from help don' work.
Dim sgRunTimeVersionT : sgRunTimeVersionT = ""
LVRuntime.Init sgRunTimeVersionT
Dim objVI Set objVI = LVRuntime.LoadVI(AutoActPath & "TestVI.vi")
Call objVI.run(True)
'Clean up
Set objVI = Nothing
LVRuntime.DeInit
I get message "unspecified error occourred".
Who can help? I think, it's a very common problem.
(4,229 Views)
Hello Martin!
ExtProgram is not able to do it but you can use the Windows Shell Objetct to solve the task:
Option Explicit
Dim oWshShell
Dim oExec
Set oWshShell = CreateObject("WScript.Shell")
Set oExec = oWshShell.Exec( Deskdrv & "\Labview\TestVI.exe" )
Do While oExec.Status = 0
  Call Pause(1)
Loop
MsgBox "VI Finished!"
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,218 Views)
Thank you for your answer.
Running program in Windows Schell works fine with a standalone exe like "notepad.exe".
To start a compiled Labbview VI at this way don't work. The VI appear but it dos not start and hang up. Killing  task with taskmanager, the VI finished message appear. I think, the VI don't find the Labview runtime envirement when starting in this context.
(4,208 Views)
Hello Martin!
I had tested the script with one of our VI's and it worked fine in a LV 7.1 RT!
Perhaps there is a problem with the working directory for the VI. Please try the script with this line before the Exec call:
oWshShell.CurrentDirectory = Deskdrv & "\Labview\"
Matthias
Matthias Alleweldt
Twigeater?
(4,203 Views)
Thank you, I 've solved the problem.
The point was't the call of the VI itself, but the usage of  pause() -function in wait loop. The executuon of pause seams to block correct executuon of VI.
Here is my solution:
Dim oWshShell
Dim oExec
oWshShell.CurrentDirectory = Deskdrv & "Labview\"
Set oExec = oWshShell.Exec( "TestVI.exe" )
    call MsgBoxDisp("VI is running",,,, 1)    'msgbox whith timeout of 1s
Loop
(4,198 Views)
Hello Martin!
Verry interesting and good that you found a solution! Why did it worked with our VI?
In older DIAdem versions Pause blocked the message loop, but this was changed some versions ago. To use MsgBoxDisp has also the advantage to workaround a 10.1 bug.
Matthias
Matthias Alleweldt
Twigeater?
(4,193 Views)
Hi bohm,
Note that if you have DIAdem 10.1 or later, there is a new object variable called "LVRuntime" with which you can efficiently and easily run LabVIEW code from anywhere in DIAdem.  DIAdem 10.1 also ships with an example ("Calculating the Bessel Function with a LabVIEW VI") which launches a SUDialog that calls a LabVIEW VI and waits for it to finish before proceeding with the rest of the VBScript code-- sounds very like what you're wanting to do.
Note also that DIAdem 10.1 installs the LabVIEW 8.20 runtime engine,
Brad Turpin
DIAdem Product Support Engineer
(4,186 Views)
