02-14-2007 01:30 PM
02-15-2007 10:52 AM
Hi George,
Are you saving the TDMS file with LabVIEW or DIAdem? In LabVIEW, you wire a data array of a particular data type to be written to the TDMS file, so the precision used on disk will match that of the data type. So if you're currently wiring a DBL type, converting that array to a SGL type prior to writing the array to TDMS will reduce the precision (and the disk footprint), though it may not reduce it enough for your taste. If you are wiring waveforms to the TDMS file, I believe you are stuck with DBL precision.
If you are saving the TDMS file in DIAdem, and if you have DIAdem 10.1, then you have the option of using the new ChnQuantize() function to limit the resolution of the data both inside of DIAdem and when you save it to disk. Unfortunately, DIAdem 10.1 has a bug for TDMS output when using custom quantization, though this will be fixed in the upcoming DIAdem 10.1 SP1. Still, this doesn't necessarily reduce the number of displayed digits, it just reduces the accuracy so that similar values can be saved in a smaller binary footprint. So this may not be what you're after.
Regardless of the resolution of the saved binary data, DIAdem loads all channel values as DBLs in the Data Portal, and it displays all the digits of precision corresponding to the DBL value it has in memory. However, you can always change the displayed format of a channel value in a VIEW or REPORT table by changing that column's format string. Try "d.ddd" or "d.ddde" for instance.
Ask if you have further questions,
Brad Turpin
DIAdem Product Support Engineer
02-15-2007 11:10 AM
Brad,
I'm saving the data with LabVIEW so it sounds like there's not much I can do. The data is being imported into Excel with the TDMS importer. I told the guys who are working with the data that probably the best thing to do is limit the precision in Excel to the precision of the instrument (4 decimal places).
George
02-16-2007 09:45 AM
Hi George,
Now that I know you're saving the data in LabVIEW and reading it in Excel, I have a much better idea what's going on. If you show an array of these values on a front panel indicator, do they show the desired precision or the extra precision which you don't want? If you're saving the data as a DBL array or probably even as a SGL array, then I would expect the precision to show up in Excel just as it looks in LabVIEW. If you see too much precision in LabVIEW, then the simplest solution is to truncate the data in LabVIEW prior to saving it to file. Of course you lose resolution by doing this, but it sounds like that extra resolution is either meaningless or more distracting than useful.
If on the other hand the data looks correct in LabVIEW but shows up with extra digits in Excel, I'd recommend that you send me the part of your LabVIEW code which is doing the writing. I'm not sure why that would be the case.
By the way, are you using DIAdem 10.1 and the improved DataFinder these days? Will it make sense for your groups to use the DataFinder Server Edition, or is the local DataFinder on each DIAdem client sufficient? Thanks for all the Beta testing.
Brad Turpin
02-16-2007 10:57 AM
02-19-2007 09:36 AM
Hi George,
This is what I am talking about-- you have to delete the precision that you don't want from the values in the LabVIEW array prior to saving those values to the file.
Brad Turpin
02-19-2007 11:21 AM
02-20-2007 11:02 AM
Hi George,
OK, I sent that VI off to you a bit quickly yesterday. You're right that when the number is scaled back to its original value as a SGL that the same "extra" precision issue crops back up. I went ahead and populated the VI with default data and changed the "1000" constant to the data type DBL in order to force the values saved to TDMS file to also be of type DBL. On my computer this now results in the 3 digits of precision I was aiming at-- in both DIAdem and Excel.
Let me know if you see something different on your end,
Brad Turpin
02-20-2007 11:11 AM
