DIAdem
Save data and report in subfolder
I spend one day  trying to solve this "stupid" thing  but now I raise my white flag.
Hope someone could show me the way.
In my script I want to organize the output result in such a way to have:
tdm files in "testdata" folder
pdf + xls in "testdata"\"document" folder
I'm able to create the testdata folder, but no idea how to create the subfolder.
The testdata folder should be a variable because it change test by test.
I've highlighted the error in my script.
dim myfold
myfold = inputbox("Inserire nome della prova", "diadem", DataSetName)
call foldercreate(DataReadPath & myfold)
call foldercreate(DataReadPath & myfold\"documents")
rem 'Save elaborated data
rem If (FileNameGet ("NAVIGATOR", "FileWrite", DataReadPath & DataSetName & myfold & "." & DataExtension) = "IDOk") Then
rem Else 'Dialog was canceled
  rem Call MsgBoxDisp ("Data saving was canceled")
rem End If
Bye
(6,385 Views)
Giova
You were very close to have it work.  Just some syntax issues.
The lines below will make the documents directory under /testdata/
dim myfold
callfoldercreate(DataReadPath & myfold)
callfoldercreate(DataReadPath & myfold&"\documents")
You mentioned that PDF and Excel were the next files to create. I have done both.
Here is some helpful PDF making code for report output.
dim ofso
Set ofso = CreateObject("Scripting.FileSystemObject")
'ReportPrintTransparency = 1 ' needed to display transparency colors
REPORTPrintAsGraphic = 0' needed to display transparency colors
PDFResolution = "600 DPI"
PDFOptimization = true
iffilex(gsPDFFileFullPath) then
ofso.DeleteFile(gsPDFFileFullPath)
endif
CallPicPDFExport(gsPDFFileFullPath)
Paul
(6,361 Views)
Paul,
Thanks you so much for the help.
But I still have the same trouble to create the pdf file in the correct folder (documents).
If I apply the same rule of the foldercreate function, my pdf was create in the testdata folder with the name: documentstestdata.pdf.
dim ofso
REPORTPrintAsGraphic = 0 ' needed to display transparency colors
if filex(DataReadPath & myfold&"\documents" & DatasetName) then
ofso.DeleteFile(DataReadPath & myfold&"\documents" & DatasetName)
end if
Call PicPDFExport(DataReadPath & myfold&"\documents"& DatasetName)
(6,355 Views)
Accepted by Giova
Giova
Just put in the  "/" between the Documents and the file name.
Paul
(6,350 Views)
Perfect!
(6,341 Views)
