Hello Ham,
Which version of DIAdem are you running? In DIAdem 9.0, you should be able to display a string channel in DIAdem VIEW just like you display numeric channels. To do this, open the DIAdem VIEW panel, click the fly-out menu "Predefined screen partitioning", then select the first icon ("One channel table with all channels"). You will see all your channels, including the text channel.
You can transfer channels from DIAdem to other applications via the Windows clipboard using the VBScript ChnClpCopy command, like this:
call ChnClpCopy("1-4")
I can easily use this command to transfer both numeric and string channels between DIAdem and Excel, but I don't have Matlab to test this with. I hope this works for you.
David Mc.
NI App
lications Engineer
