DIAdem
Script-based import of multiple csv files to one channel group / changing the group/channel properties
DIADEM 2014 (32Bit)
I want to use a script to import some csv-Files into the data portal. The csv file contains only one data row. As result i want to have one channel group containing all the data (one channel for each imported file) and i want to change to property of the group (only the name) and the properties of the channels (Name, Unit, ....).
This is what i have right now:
Dim RunFile_Path, RunChannelObj, iLoop
iLoop = 0
for Each ArrayElement in Runlist_3310
RunFile_Path = Data_Path & string(4 - Len(Volume_ID), "0") & Volume_ID & string(4 - Len(Runlist_3310(iLoop)), "0") & Runlist_3310(iLoop) & ".T24"
Set RunChannelObj = DataFileLoad(RunFile_Path,"CSV","Load")
Call ChnPropValSet(iLoop+1,"Name",Runlist_3310(iLoop) & "-LOBSTx")
iLoop = iLoop + 1
As result i have a channel-group for each imported file/channel.
How can i add the second file/data to the channel-group i created in the first loop?
Is it possible to change the name of the new channel right after the DataFileLoad?
How can i change the other properties of the channel?
Thank you all in advance for your help.
Message 1 of 14
(4,969 Views)
In your case you can simplyfy your life by using
DataFileLoadSel
Which will return the channel object directly and not create a new group on its own.
So you do not have to use the move method.
It returns a list of loaded elements. Be aware that I put
(1)
at the end of the line always selcting the first element.
Option Explicit
data.Root.Clear
dim grpO : set grpO = data.Root.ChannelGroups.Add("target")
grpO.Activate
dim chO : set chO = DataFileLoadSel(CommonDocumentsPath & "Data\example.csv","CSV","[1]/[1]","Load")(1)
chO.Name = "one"
chO.properties("description").value = "one description"
chO.Name = "two"
chO.properties("description").value = "two description"
Message 2 of 14
(4,933 Views)
Thank you, that was i was looking for. Works fine.
Message 3 of 14
(4,930 Views)
Now I have a lot of generated groups with the right channels.
Some of the groups are shown expanded, some are shown collapsed in the data portal.
Is there a vb command the collapse/expand the group nodes?
Message 4 of 14
(4,925 Views)
I assume not by command but there is context menue entry in the portal.
Message 5 of 14
(4,919 Views)
Now I want to make FFTs of some Channel-Groups.
So I create a new group and set them active. After that I want to loop through the channel group, make the FFT and rename the resulting 2 channels (frequeny and amplitude).
dim grp3310LOBSTzFFT : set grp3310LOBSTzFFT = data.Root.ChannelGroups.Add("3310-LOBSTz_FFT")
FFTIndexChn      = 0
'----------- Window Functions -----------
FFTWndFct        = "Hanning"
FFTWndPara       = 10
FFTWndChn        = "[1]/Time_RoughRoad"
FFTWndCorrectTyp = "Random"
'------------ FFT Functions -------------
FFTCalc          = 0
FFTAmpl          = 1
FFTPhase         = 0
FFTCepstrum      = 0
FFTAmplType      = "Ampl.Peak"
FFTAverageType   = "arithmetic"
FFTAmplExt       = "No"
FFTAmplFirst     = "Amplitude"
'------------ Time Intervals ------------
FFTIntervUser    = "LengthStartOverl"
FFTIntervOverl   = 50
FFTNoV           = 0
FFTIntervPara(1) = 7
FFTIntervPara(2) = 1024
FFTIntervPara(3) = 1
Dim i
grp3310LOBSTzFFT.Activate
for i = 1 to grp3310LOBSTz.Channels.Count
Call ChnFFT1("[1]/Time_RoughRoad", ????????
How can I loop through all channels in the group called grp3310LOBSTz ?
Message 6 of 14
(4,908 Views)
Please have a look at the help entry "root object" wheer you will find some examples.
Object: Root <Data>
Option Explicit
dim chO : for each chO in data.Root.ChannelGroups("grp3310LOBSTz").Channels
  chO.Properties("description").Value = "abc"
Message 7 of 14
(4,899 Views)
Thank you for this hint.
How is it possible to loop through the channels of a group and make a FFT?
Call ChnFFT1("[1]/Time_RoughRoad", grp3310LOBSTz(1))
Sure, that doesn't work. Is there a pointer/reference to the first, second, third,... element of the channel group?
Message 8 of 14
(4,896 Views)
My solution looks like this now:
for each ch0 in data.Root.ChannelGroups("3310-LOBSTz").Channels
chName = ch0.Properties("Name").Value
'--Call ChnFFT1("[1]/Time_RoughRoad", chName)
Call ChnFFT1("Time_RoughRoad", chName)
What is the difference between the statement "[1]/Time_RoughRoad" and "Time_RoughRoad"?
I want to rename the two channels (frequency and amplitude) that are created by the ChnFFT1 command.
Is it possible to do it in the same for each..next loop?
If not I have to do it after FFT creation in a second loop..correct?
Message 9 of 14
(4,890 Views)
chO.GetReference(eRefTypeIndexIndex)
will return a string to be used.
If you use just the channel name it will always refer to the active group.
Be aware that [1] will always use the first group.
Message 10 of 14
(4,882 Views)
