DIAdem
Script to collate tdms files
Has anyone written a script to automaticallycollate all data for a given sample or batch number and put it into a tdm file,say daily?
What I want to do is enable a user to instantly changecomparison vector. Say for example, I want to compare photoluminescence ofsamples who have current greater than a particular threshold (two different experimental techniques performed on the same sample). If I leave the tdms files of each technique separate, I'd run a DIAdem group search for a current maximum greater than the threshold, whichwould give me sample IDs, which I could search against filetype to get all thephotoluminescence data for those samples.
If I had each sample's data collated, I could search within thesummary files for current > threshold, and then directly compare all of thePL channels to each other.
(3,679 Views)
Hi CReese,
Would you please post or email me a representative set of TDMS files that you want to run this analysis on?  My answer to your questions will depend in part on how you have stored your data in the TDMS files, and it would be easiest for me to evaluate this by simply looking at the files myself.  Plus, if I had your files I could write a few test scripts and see how they run on your actual data.
Brad Turpin
DIAdem Product Support Engineer
brad.turpin@ni.com
(3,658 Views)
