DIAdem
Searching for maximum FFT values
I have lots of vibration data that was recorded in multiple length time segments.  For example, one group may contain 5 seconds of data, and the next group may contain 30 seconds.  Each group contains 15 channels of accelerometer data (5 sensors with 3 axis/sensor).
What I would like to do is pragmatically scan through the data streams and capture the highest amplitude accelerations that occur in a given 1 second interval within a specified window of frequencies.
The data was collected at a sample rate of 1kHz resulting in FFTs that go up to 500Hz.  However, I am actually only interested in frequencies between 1Hz and 50Hz.
Is there a way that this could be done?
Doane
(5,128 Views)
Hi DBuskar,
If I get you right, you should filter the original channels - either with digital low pass (0 – 50 Hz) or a band pass filter (1 – 50 Hz). Then calculate the start and stop row for your 1 second interval and calculate the max amplitude with the statistic function. Repeating these 15 times for all channels it makes sense to create a script for these steps.
Greetings
Walter
(5,118 Views)
Hello Walter, and thanks for the reply.
I would need to calculate the max amplitude within the 1-50 Hz range first in order to determine where my desired 1 second interval is.
I agree that a script is in order.  I have started doing this manually, but doing so is taking me a very long time.
(5,102 Views)
Hi DBuskar,
Please find attached an example for your request.
I hope this shows what you are looking for.
Greetings
Walter
(5,087 Views)
