DIAdem
open Excel using DDE in DIAdem
Hi everyone,
I found that in DIAdem Sript we may use the DDEOpen command to open Excel table.
As I try to run the example sript in DIAdem help. It requires to open the excel.exe before it uses the DDE interface.
Is there a way to call Excel from script.
And I always have some DDE error, to say the DDE server doesn't react to the DDEOpen command, even if I've open an excel sheet.
Any suggestions?
(4,891 Views)
Hello wilburwu
I am far from being a programmer, but this seems to work to open an empty Excel workbook from DIAdem:
Dim Excel                     'Excel object variable
Set Excel = CreateObject("Excel.Application")
Excel.Visible = True ' Starts Excel
Excel.Workbooks.Add  ' Creates a new Excel document
Maybe this will get you on the right path ...
     Otmar
Otmar D. Foehner
(4,883 Views)
