DIAdem
View coordinates window is off-screen
I have an unconventional dual-monitor setup while my laptop is docked. It's resulted in the coordinates window being located far off-screen. I've moved the secondary monitor around the desktop area to try and locate the window to move it back within view, but have not had success. I've undocked to try and locate the window but have not been successful. I've reset DIadem but this has not brought the window back in view. DIadem isn't very handy for my use without that window.
(6,091 Views)
Accepted by topic author XGC750
Hi XGC750
There are two solutions:
The first one is decribed here: http://www.howtogeek.com/howto/windows/bring-misplaced-off-screen-windows-back-to-your-desktop-keybo...
The second is to modify the Config.ini file of DIAdem. You will find it here c:\Users\Username\AppData\Local\National Instruments\DIAdem\Version\ (username is placeholder for your login name and Version for the current DIAdem version e.g. 2012. Close DIAdem first and then change the psosition text to:
POSITION=0,0
Hope this helps!
Winfried
(6,087 Views)
Ah, that looks helpful.. I'll try it out a little later today and report back.
(6,077 Views)
The first solution in the link goes through how to locate a window that is registered as a window with windows explorer, thus giving it a bar on the taskbar. Unfortunately the coordinate window isn't, so I can't locate it with the "move" action.
On the second solution, I should have been specific that I'm using windows XP, and a corporate image at that. I don't find appdata in my user folder (for XP that's C:\Documents and Settings\User\.appdata\). Where's the config file in XP?
EDIT: I actually just tried to use only the keyboard shortcuts immediately after enabling the coordinate window. DIadem's main window loses focus, so I figured perhaps the coordinate window is given focus. So, I hit Alt+space and the dialog box appears on my screen nearest to the location of the coordinate window. From there I can select "move" with the mouse and by moving the mouse after that, the coordinate window appears underneath it. Fixed!
Howtogeek:
Note: For keyboard savvy people, you can just alt-tab to the window, use Alt+Space, then M, then Arrow key, and then move your mouse.
(6,070 Views)
