DIAdem
Select case structure
I am trying to use the Select Case to be something like below:
Select Case RedTemp
  Case 20 to 30
      WriteTemp = 10
  Case Else
      WriteTemp = 0
end select
It appears that the "TO" operator is not active in the Select Function in DiaDEM. I would just like to confirm this as being true and see if anyone may have a work around.
(5,764 Views)
Hello Blane63580,
We use Visual Basic Script (VBS) to automate DIAdem. Therefore we extended VBS so that it is able to understand the DIAdem commands. VBS is a subset of VBA and doesn't support "TO" for in the "select case" command. Here is the description of the VBS command “select case”and a small example:
Select Case
Depending on the value of an expression, this Select Case conditional statement executes only one of several possible statement groups.
Select Case TestExpression
Case  ExpressionList
  Statements
[Case Else ExpressionList
    else_statements]
End Select
TestExpression Any numeric expression or string expression.
ExpressionList A list separated by commas with one or more expressions.
Statements One or more statements to execute if the test expression agrees with one of the expression values in its Expressionlist_n.
else_statements One or more statements to execute if the test expression does not correspond to any of the specified expressions.
Dim iVal
iVal = InputBox("Please enter a value")
Select Case iVal
Case 1, 3, 5, 7, 9
  Call MsgBox("Odd number")
Case 2, 4, 6, 8, 10
  Call MsgBox("Even number")
Case Else
  Call MsgBox("Number less than 1 or greater than 10")
End Select
Greetings
Walter
(5,755 Views)
