DIAdem
automatic channel renaming
I have Diadem 2011 and I am facing a problem when I try to automatically rename a list of channel (loaded in my data portal). My list of channel and their corresponding new names are written in a text file with the following syntax :
initial name1, new name1
initial name2, new name2
initial name n, new name n
My first idea was to import this .txt file in order to create 2 channels called for example "old channel" and "new channel" and to use the following renaming command in a loop like this:
For i=1 to length (old channel)
Data.Root.ChannelGroups(1).Channels(old channel (i)).Name = new channel(i)
next
This command works correctly when I replace old channel(i) and new channel(i) by a string like for example "channel1" and "channel2". In my opinion, there is a problem with the data type, but I don't manage to solve it.
I also tried the data type conversion but without success.
Thank you by advance for your help
Jeremy
(6,213 Views)
Accepted by topic author Jeremy_TCL
Hi Jeremy,
I'd recommend you read the name lookup file into memory instead of channels in the Data Portal.  The below code uses 2 parallel string arrays, but the Dictionary object is another good way to go.
NameArrayFilePath = CurrentScriptPath & "Name Arrays.csv"
Call ReadNameArrays(OldChanNames, NewChanNames, NameArrayFilePath)
Set Group = Data.Root.ActiveChannelGroup
jMax = Group.Channels.Count
FOR j = 1 TO jMax
  IF Group.Channels.Exists(OldChanNames(j)) THEN
    Set Channel = Group.Channels(OldChanNames(j))
    Channel.Name = NewChanNames(j)
  END IF
NEXT ' j
Sub ReadNameArrays(OldChanNames, NewChanNames, NameArrayFilePath)
  Dim j, f, fso, Cols
  Set fso = CreateObject("Scripting.FileSystemObject")
  Set f = fso.OpenTextFile(NameArrayFilePath, 1)
  ReDim OldChanNames(0)
  ReDim NewChanNames(0)
  Do While NOT f.AtEndOfStream
    Cols = Split("," & f.ReadLine, ",")
    IF UBound(Cols) > 1 THEN
      j = j + 1
      ReDim Preserve OldChanNames(j)
      ReDim Preserve NewChanNames(j)
      OldChanNames(j) = Trim(Cols(1))
      NewChanNames(j) = Trim(Cols(2))
    END IF
  Loop ' Unitl EOF
  f.Close
End Sub ' ReadNameArrays()
Brad Turpin
DIAdem Product Support Engineer
(6,188 Views)
Thank you very much!
(6,134 Views)
