DIAdem
Selecting channel in script ignoring group number
Reviewing large quantities of CAN data performing some calculating to get some basic values, so to save time I have used the script record mode to produce a basic script, however I'm assuming as a result of how the CAN decoder works the groups don't always end up in the same order, so it is just stopping because there isn't a channel in that group with the correct name.
Is there a way of ignoring the group number and searching the entire data portal for the channel name?
Option Explicit 'Forces the explicit declaration of all the variables in a script.
Call Data.Root.ChannelGroups.Add("Power Calcs", 1).Activate()
Set ChnResult = ChnMul("/HVBusVoltage", "/TotalHVBatteryCurrent", "/Bus Power")
Set ChnResult = ChnUnitConvert("[1]/Bus Power", "/Bus Power", "kW")
Set ChnResult = ChnLinScale("[1]/Bus Power", "/Bus Power", -1, 0)
Call ChnClpCopy("[55]/Time", True)
Call ChnClpPaste(1295, True)
Call Data.Move(Data.Root.ChannelGroups(1).Channels("Time"),Data.Root.ChannelGroups(1).Channels,1)
Set ChnResult = ChnUnitConvert("[1]/Time", "/UnitConverted", "h")
Set ChnResult = ChnOffset("[1]/UnitConverted", "/UnitConverted", 0, "first value offset")
Data.Root.ChannelGroups(1).Channels("UnitConverted").Name = "Time(h)"
(3,050 Views)
Accepted by DEKieranrb
Data.GetChannels(ChannelName)
Warning: This will only give you the first occurrence of a channel with that name.  If you have multiple channels with the same name in different groups, then you can use:
Data.GetChannels("*/" & ChannelName)
This will create a collection of all channels named "ChannelName" from any number of groups
(3,018 Views)
Hi Thanks for the help. I am a novice at this could you give me a little more context as to how I can implement this?
Specifically in this line: Set ChnResult = ChnMul("[55]/HVBusVoltage", "[55]/TotalHVBatteryCurrent", "/Bus Power")
If HVBusVoltage and TotalHVBatteryCurrent aren't in group 55 then it doesn't work. None of my channel names are in more than one group.
Thanks.
(2,990 Views)
Something lie this could work:
Dim currentChannel, voltageChannel
Set currentChannel = Data.GetChannel("TotalHVBatteryCurrent")
Set voltageChannel = Data.GetChannel("HVBusVoltage")
Set ChnResult = ChnMul(voltageChannel.GetReference(eReferenceIndexName), currentChannel.GetReference(eReferenceIndexName), "/Bus Power")
(2,965 Views)
Hi DEK,
If the channel names you want to reference exist in one and only one Group, then you can ignore the Group part and use that channel name as a string constant:
Set ChnResult = ChnMul("HVBusVoltage", "TotalHVBatteryCurrent", "/Bus Power")
If, alternatively, the Group/Bus name is always the same for these channels, then you can include the Group Name instead of the Group Index:
Set ChnResult = ChnMul("GroupNameABC/HVBusVoltage", "GroupNameABC/TotalHVBatteryCurrent", "/Bus Power")
Brad Turpin
Senior Technical Support Engineer
(2,886 Views)
Hi All,
The suggestion from gskylr is also excellent.  I prefer using object variables to string constants, but many customers find using string constants more intuitive than object variables.  I just wanted to add, that if you're using channel object variables, you don't have to request and pass the reference when using as a parameter of a function or command:
Set ChnResult = ChnMul(voltageChannel, currentChannel, "/Bus Power")
Brad Turpin
(2,885 Views)
