DIAdem
Selecting the correct .csv plugin when multiple are available.
I'm having a problem selecting (through my script) a specific .csv plugin to load my data.
I am using a  Call FileDlgShow command:
Call FileDlgShow(DataReadPath, "Thermotron_CSV,*.csv|TDM Files,*.tdm|DAT Files,*.dat|All Files, *.*", "Data selection", True)
When I execute this command, I recall a plugin format that is not the “Thermotron.CSV”.
It looks like it is using a different plugin.
Any Ideas?
(4,193 Views)
The DataFileLoad command has a second parameter where you can specify your plugin.
Your Code should look like this:
Option Explicit
if "IDOk" = FileDlgShow(DataReadPath, "Thermotron_CSV,*.csv|TDM Files,*.tdm|DAT Files,*.dat|All Files, *.*", "Data selection", True) then
  For iCount = 0 To Ubound(FileDlgNameList)
    Call DataFileLoad(FileDlgNameList(iCount), "Thermotron_CSV")
end if
(4,167 Views)
Accepted by topic author SDuff
I have seen that you had multiple filters.
The following code can be used for this. There is also the ability to figure out the selected filter.
Option Explicit
if "IDOk" = FileNameGet("ANY", "FileRead", DataReadPath, "Thermotron_CSV,*.csv,TDM Files,*.tdm,DAT Files,*.dat,All Files, *.*", "All.lst", True, "Data selection") then
  Dim MyFileNames : MyFileNames = Split(FileDlgFileName,"|")
  dim filePath : For each filepath in MyFileNames
    select case UCASE(FileDlgExt)
      case ".TDM" Call DataFileLoad(filePath, "TDM")
      case ".DAT" Call DataFileLoad(filePath , "DAT")
      case ".CSV" Call DataFileLoad(filePath, "Thermotron_CSV")
      Case Else DataFileLoad(filePath)
    end select
end if
(4,158 Views)
This is perfect. Thank you so much again for your help !!!
(4,147 Views)
