DIAdem
SoMat_SIE DataPlugin Error: Access Violation while executing DataFileLoad
Frequent error using command "Load Data" of .sie data files into Data Portal: Internal Data.
Using SoMat_SIE DataPlugin v 1.0.0.6346 [latest] with DIAdem 2017 SP1 64-bit.
When loading data file into Data Portal: Internal Data, frequent error of:
"Error wile executing "DataFileLoad("DataFileName.sie")" command
Error type:  ACCESS VIOLATION
Error address: 000168A9
Module name:libsie.dll"
(3,066 Views)
Accepted by topic author ATarman
Hi ATarman,
Just to confirm is this the Data Plugin that you are using?
SoMat_SIE DataPlugin: https://www.ni.com/en/support/downloads/dataplugins/download.hbm-dataplugin-for-somat-sie.html
Do you mind sharing which operating system you are using? Have you noticed this behavior in multiple OS?
Have you tried uninstalling and reinstalling the Data Pluggin?
1. Remove the Data Plugin from DIAdem
2. Uninstall the Data Plugin.
3. Reinstall the Data Plugin
(3,041 Views)
Thank you for the suggestions.
I am running Windows 7 Enterprise.
I did uninstall and reinstall the DataPlugin.  I have not had the error since re installation, but will follow-up if it occurs again.
Thank you for your assistance.
(3,016 Views)
