DIAdem
Sort Loaded Groups in Portal According to Source Filename Property
I am using a script to load 4 files in th Data portal and later graph some selected channels. The problem is that when I choose the files through a dialog box, the order gets mixed up in the data portal. I would like the files to be sorted according to the source filename. Here is the loading script:
Dim i, intLoop, Group,b
Call Data.Root.Clear()
If FileDlgShow(DataReadPath,"TDMS Files,*.tdms","DataSelection",True) = "IDOk" Then
  For i = 0 to UBound(FileDlgNameList)
Call DataFileLoad(FileDlgNameList(i),"TDMS","Load") DataFilename,FileImportFilter,ImportAction
End If
 Is there any way I can do that?
Thank you!
(4,482 Views)
Accepted by Saloutios
Hi Saloutios,
You can sort the FileDlgNameList Array for example using the BubbleSort algorithm:
Sub BubbleSort(arr)
    Dim value, numEls
    Dim index
    Dim firstItem
    Dim indexLimit, lastSwap
    ' account for optional arguments
    numEls = UBound(arr)
    firstItem = LBound(arr)
    lastSwap = numEls
    Do
        indexLimit = lastSwap - 1
        lastSwap = 0
        For index = firstItem To indexLimit
            value = arr(index)
            If (value > arr(index + 1)) Then
                ' if the items are not in order, swap them
                arr(index) = arr(index + 1)
                arr(index + 1) = value
                lastSwap = index
            End If
    Loop While lastSwap
End Sub
The input array is sorted after you called that procedure.
Hope this helps
Winfried
(4,464 Views)
@winner wrote:
Hi Saloutios,
Sub BubbleSort(arr)
    Dim value, numEls
    Dim index
    Dim firstItem
    lastSwap = numEls
    Do
        lastSwap = 0
            value = arr(index)
                lastSwap = index
            End If
    Loop While lastSwap
End Sub
Hope this helps
Winfried
Hi Winfried,
Thank you very much for the reply. That worked just fine for me!
Cheers!
(4,446 Views)
