DIAdem
Specifying page size using pdfexport()
I have been trying to specify a specific page size for a PDF.  I have figured out how to use the picratio and other variables to change the TDR within DD.  However, the PDFexport ignores the printwidth setting and always uses 8.5x11.
I was able to manually change the page size by printing to the "diadem pdf printer" but i need scripted solution.
Is there a way to use the picprint and "printname" variable to specify a page size?
something like
printname = "diadem pdf printer,LPT1,11x17"
Here is what doesn't work
dim w,h
PicInScal = False ' relative positioning
PicFrame = False ' we'll handle the frame ourselves
w=11
h=17
picratio= h/w
PicwidthInScal = w-0.5
PicHeightInScal = h-0.35
PrintTopMarg = 0.17 ' top page page
PrintLeftMarg = 0.25 ' left page margin
PrintWidth = w ' page width
CALL PICpdfexport(PATH)
Jim West
Message 1 of 10
(6,302 Views)
Hey Jim,
After trying several variations, I don't think this is going to be possible.  I seemed to get programmatic export to PDF to work after script recording myself manually exporting the PDF with my chosen settings and then immediately running the recorded script, but that's all.  Other than that, though I can seem to set the side of the TDR in DIAdem itself, it always seems to generate a PDF of standard size.
I will file feedback to the DIAdem R&D team to take a look at this for a future release of DIAdem.  Thanks for providing this feedback, Jim.
Derrick S.
Product Manager
NI DIAdem
Message 2 of 10
(6,266 Views)
Can you look at the 11.1 beta and see if it works there?
jim
Message 3 of 10
(6,263 Views)
Hey Jim,
You're a step ahead of me!
I copied and pasted your exact code (save for the fact that I added an absolute path to the PICPDFExport command) into the DIAdem 11.1 beta and ran it.  The attached PDF is what I got as an output.  Is that what you were looking for?  Note that I used, simply, the example TDR, so things are a little out-of-whack in terms of design and layout.  I am using Adobe Acrobat 8.1.5.
Message Edited by DRock on 06-02-2009 12:00 PM
Derrick S.
Product Manager
NI DIAdem
Message 4 of 10
(6,260 Views)
Yes, that is what I want but in V11.0 Smiley Wink
jim
Message 5 of 10
(6,252 Views)
Hi Jim,
For DIAdem 11.1 we done several improvements in the context of PDF.
In DIAdem 11.0 I've tested the following:
dim w,h
w=11
h=17
picratio= h/w
call PrintMaxScale
CALL PICpdfexport("D:\Test\ttt")
It seems to work.
Greetings
Walter
Message 6 of 10
(6,236 Views)
I still can't get this to work.  I have 11.1 beta.  I have copied the script from prior posts.
Diadem shows the correctly sized report but when the PDF export is made; the report is jammed into 8.5x11.  Sample attached
I have adobe reader 9.1.1
jim
dim w,h
w=28
h=11
picratio= h/w
call PrintMaxScale
CALL PICUPDATE
CALL PICpdfexport("C:\Development\Spartan\www\temp\test3.pdf")
Message 7 of 10
(6,185 Views)
Hey Jim,
I updated my Adobe Acrobat reader to 9.1.2 (I was using 8.1.6) and used the exact same script commands that Walter posted above.  In both DIAdem 11.0 and DIAdem 11.1 using that script and that script alone, I get a resulting PDF that is 11x17.
Could you try replicating that exact process?
  1. Update Adobe to match  me, if possible.
  2. Open up a new script and copy/paste Walter's exact commands.  Use nothing else in the SCRIPT.  Use our default example REPORT template.
  3. Run the script and view the resultant PDF.
I'd like to see if simplifying the process by using a script that contains only Walter's commands and our default example TDR yields the same results, as this is the test that I successfully ran.
Let me know?
Derrick S.
Product Manager
NI DIAdem
Message 8 of 10
(6,158 Views)
I did as you suggested and it didn't work.  However, I know why yours works.
I had a wild idea that using the manual Diadem PDF printer will affect the script output.
I did this process:
  1. Ran the script on example TDR  --> got 8.5x11 output
  2. Manually printed
    1. File Menu ->Print
    2. Select "Printer...'
    3. Select "DIAdem PDF Export"
    4. Select 11x17
    5. press OK
    6. Press Min Borders
    7. Press OK
    8. Enter  file name
    9. Confirmed 11x17 size
  3. Ran the script again on example TDR --> got 11x17 output
If you look at your current "diadem PDF export" printer settings, I bet they are 11x17.
Better yet, I bet if you change the size in your script, you will still get 11x17.
Jim
Message 9 of 10
(6,152 Views)
Hey Jim,
I think we're going to have to use that as a workaround until R&D can investigate this further.  As a result of this post, they are aware of the behavior you've been seeing.
Derrick S.
Product Manager
NI DIAdem
Message 10 of 10
(6,106 Views)
