DIAdem
Text object relative position problem
I have a problem specifying object's relative position using scripts in DIAdem.
I am trying to use the RelPosLst variable to set text relative position to "right". However, when I run the script, I always get "center" as text's relative position. The code example follows:
 Call GraphObjNew("FreeText","Text3")
Call GraphObjOpen("Text3")
TxtPosX = 14.7
TxtPosY = 57
TxtBold = True
 TxtTxt = "Site: " & Site
TxtFont = "Arial"
TxtSize = 4
RelPosLst = "Right"
Call GraphObjClose("Text3")
Am I doing something wrong?
Thank you
Egor
(4,419 Views)
Accepted by topic author Ermak
Hi Egor,
the variable RelPosLst is only the list variable of the positions, you have to use the variable TxtRelPos in your code.
Tip: if you want to get all variables of a dialog, open it and press "Strg + a". With this you copy all (scriptable) variables of the dialog to the clipboard and you can paste it in your VBScript. This is much easier than searching the help file.
In code :
TxtPosX = 14.7
TxtPosY = 57
TxtBold = True
TxtFont = "Arial"
TxtSize = 4
TxtRelPos = "right"
Call PicUpdate
Regards Sven
(4,414 Views)
Message Edited by Ermak on 06-17-2009 01:59 PM
(4,411 Views)
