DIAdem
Statistical dispersion of repetitive action
Hi Esber,
Your VBScript syntax is off.  You look like you want to refer to a channel in the Data Portal, but you do so with an explicit string constant, like "[1] PB2 Sm100".  Instead create a channel object variable and use that to read and write values from/to that channel, like this:
Dim a, n, aMax, ChannelA, ChannelB, ValA, ValB
Set ChannelA = Data.GetChannel("[1]/PB2 Sm100")
Set ChannelB = Data.GetChannel("[1]/PA22 Sm100")
aMax = ChannelA.Size
FOR a = 1 TO aMax
  ValA = ChannelA(a)
  ValB = ChannelB(a)
  IF ValA < ValB THEN
    n = n + 1
    ChannelA(a) = ValB
  END IF
NEXT
Brad
Message 11 of 12
(364 Views)
Hi Esber,
What version of DIAdem are you using?  The ChnEventCopyValues() command was apparently released after your DIAdem version.  Replace that one command line with the following two, and it should work for you:
    Call DataBlCopy(RawXChannel, P1, Pn-P1+1, CycXChannel, 1)
    Call DataBlCopy(RawYChannel, P1, Pn-P1+1, CycYChannel, 1)
I was able to reproduce the error you described in DIAdem 2015, and making this substitution allowed the script to finish the cycle extraction.
Brad Turpin
Message 12 of 12
(349 Views)
