10-15-2018 03:17 PM
Hi Esber,
Your VBScript syntax is off. You look like you want to refer to a channel in the Data Portal, but you do so with an explicit string constant, like "[1] PB2 Sm100". Instead create a channel object variable and use that to read and write values from/to that channel, like this:
Dim a, n, aMax, ChannelA, ChannelB, ValA, ValB Set ChannelA = Data.GetChannel("[1]/PB2 Sm100") Set ChannelB = Data.GetChannel("[1]/PA22 Sm100") aMax = ChannelA.Size FOR a = 1 TO aMax ValA = ChannelA(a) ValB = ChannelB(a) IF ValA < ValB THEN n = n + 1 ChannelA(a) = ValB END IF NEXT
Brad
DIAdem Product Support Engineer
10-18-2018 11:31 AM
Hi Esber,
What version of DIAdem are you using? The ChnEventCopyValues() command was apparently released after your DIAdem version. Replace that one command line with the following two, and it should work for you:
Call DataBlCopy(RawXChannel, P1, Pn-P1+1, CycXChannel, 1) Call DataBlCopy(RawYChannel, P1, Pn-P1+1, CycYChannel, 1)
I was able to reproduce the error you described in DIAdem 2015, and making this substitution allowed the script to finish the cycle extraction.
Brad Turpin
