DIAdem
TDMS C DLL Error 6210 File is read only
I am trying to use VS2015 to extract data from TDMS files, however I am getting this error when I try to open the file.
6210DDC_CannotWriteToReadOnlyFileThe file passed to the library is read only and cannot be modified.
This happens with both DDC_OpenFile and DDC_OpenFileEx.
ddcChk (DDC_OpenFileEx (FILE_PATH, "TDMS", false , &file));
ddcChk (DDC_OpenFileEx (FILE_PATH, "TDMS", true, &file));
ddcChk (DDC_OpenFileEx (FILE_PATH, "TDMS", 0, &file));
ddcChk (DDC_OpenFileEx (FILE_PATH, "TDMS", 1, &file));
ddcChk (DDC_OpenFile (FILE_PATH, "TDMS", &file));
Is there a way to open read only files in VS or change the access in VS before opening?
(5,100 Views)
	ddcChk (DDC_OpenFileEx (filePath, "TDMS", 1, &file));
Works for me. It works for readonly and even for folders without write rights.
Is the NI Excel Addin capable to read the files?
Andreas
(5,077 Views)
I can open the file in with the Excel Add-on.
Additionally a .log was created with this error
ERROR: TDS Exception in Initialize: Tds Error: TdsErrFileVersionTooNew(-2510):
(5,071 Views)
The tdms_ebd.dll in you folder should be 2.5.0.49152.
Its included in the current download.
Is it possible to share a file if this is your version?
(5,061 Views)
I apologize for the delay. Initially the files were not closing properly. However upon fixing this issue I still receive the "file is read only" error. Attached is the solution I am using which I obtained from these forums. The Test01-160711.tdms file is the file I am trying to open. This file does open on both matlab and excel.
(5,006 Views)
Accepted by topic author rohrs2
The previous comments were correct, using an old dll package does not work. For everyone that is searching for the solution or how to set up tdms c dll in visual studios (VS 2015 here, Win32):
1) Grab the new c dll from the comment above.
2) Make a new blank win32 app project.
2) Move the contents of \c_dll_tdm\TDM C DLL\dev\bin\32-bit to working directory
3) Move \c_dll_tdm\TDM C DLL\dev\include folder to working directory
4) Move \c_dll_tdm\TDM C DLL\dev\lib folder to working directory
5) Move/copy contents of the \c_dll_tdm\TDM C DLL\samples\readFile.c code to your working directory/source file. (The variable length must be changed to an unsigned int for it to work with c++).
5) Follow these instuctions here to include your working directory (Step 7+). Add the working directory to your source file properties, but add the library to the Project properties
That did it for me I can successfully open TDMS files. Thank you for the help and link to new DLL! I hope this can help some people that are also new to VS.
(4,964 Views)
