DIAdem
how does diadem interpret hex values in a .csv file
If I have a .csv file with hex values such as 0x1111 verses 0xffff when I import it using the dataplugin?
(4,153 Views)
Hello Faustina,
DIAdem is using a dataplugin each time it is reading in data that is not in the TDMS file format. Under Options>>DataPlugins you can see a list of the plugins on the machine and can access the scripts used to read in the data.
Rob S
(4,126 Views)
I understand that.  When I use the DIAdem .csv plugin and the text data are hex values such as 0x1111 verses 0xffff does DIAdem properly convert the values to decimal or do they remain text?
(4,123 Views)
Hi Faustina,
The Dataplugin will read the data in as Text if you have it pull that data into a String Channel. From there you would need to use VBScript to change the text values into numeric values. If you try and read the .csv into a numeric channel you will probably just get "NoValue" for each of the data points.
The VBScript command you would use should look something like this:
HexString = "100A000F"
HexInteger = CLng("&h" & HexString)
Rob S
Rob S
(4,103 Views)
