DIAdem
TDMS save as WAV file, not always working
I have some waveforms saved in .tdms files.  I want to convert them to .wav audio files.  In DIAdem, I'd did 'Save As' then chose 'Audio .wav'. When I open the .wav file up in an audio player/editor, it is silent; it's just an empty line.
Now, my original .tdms waveform data goes from ~[-2,2]. When I scale the waveform in DIAdem down to ~.30, the .wav file then behaves properly.  Is there a different way for me to avoid this issue?  Is this due to some sort of specifications of the .wav file format?  I attached some pictures.
(5,117 Views)
Note: I think what I am doing is part of the Audio Dataplugin
(5,063 Views)
Accepted by sjgsjgsjg5509
Hi sj,
You either have to scale the waveform channels to the I32 data values yourself or happen to be in a valid scaling range for the WAV file format.  I find the former approach easier to remember:
Volume = 0.5 ' 0.0 - 1.0
FOR Each Channel In Data.GetChannels("*")
  Amplitude = MaxV(Abs(CMin(Channel)), CMax(Channel))
  Call ChnLinScale(Channel, Channel, Volume*2^31/Amplitude, 0)
  Call ChnCharacter(Channel)
NEXT
Call DataFileSave(WavFilePath, "Audio")
Brad Turpin
National Instrument
(5,059 Views)
