DIAdem
TDSErrNotTdsFile(-2503)
Hi Bbaggio,
I have a good news for you that I've already recovered the corrupted file. You can download it in the attachment. And I've figured out why the file becomes corrupt.
If you download a file from a unix ftp server to a microsoft system in ASCII mode (no matter a binary file or a text file), all the binary sequences of bytes "0A" will be replaced with "0D0A". That's why your .tdms file became corrupt. I recovered the file by replacing the bytes in the opposite way and it becomes correct.
So if you want to transfer the file from a cRIO to a PC, you must use Binary mode, but not ASCII mode.
Hope this can help you.
Xiaowei
Message 11 of 15
(3,242 Views)
Hi Xiaowei,
many many thanks for your kind message!!
you are right, I was using the "FTP Get Multiple Files VI" with the ASCII option set...
thank you for your suggestion, I will immmediately modify my source code!!
do you have a labview vi that can automatically do the byte conversion?
because I have several other tdms file with data that I would like to recover...
again many many thanks!!
Message 12 of 15
(3,234 Views)
This VI will replace "0D0A"(hex display) with "0A" in a binary file, which can solve your problem.
Message 13 of 15
(3,219 Views)
Hi Xiaowei,
many many thanks for your reply!!
with your VI I could recover the other files that got corrupted during transmission...
thank you again for your time and support!!
I really appreciated your help!!
Have a nice day!!
Message 14 of 15
(3,196 Views)
All,
I'm running into this same error unfortunately and have not been able to resolve using the recommendations provided.
I've got a remote data collection system that saved data into a TDMS file. Data gets uploaded through a server back to me and most files have opened without issues until the current one.
I have attached the file and VI here to try to understand why this may be happening,
I sincerely appreciate your assistance,
Message 15 of 15
(627 Views)
