DIAdem
Tab option in controls?
Can anyone please tell me how to activate the tab control within the tables spo that I can run through the rows with the help of the tab key?
(3,451 Views)
Hi Spria!
Which table are you referring to? There are tables available on the VIEW panel that allow you to tab between columns. There are also tables you can add to your reports. These tables do not allow you to change individual values but allow you to specify the channels to display. When you create a user dialog box (SUD) you can also add a table. With this table you can use the arrow keys to move between entries.
I hope this helps!
Sarah Miracle
(3,451 Views)
