DIAdem
how to generate a time channel when the file recorded does not have a time channel
how to generate a time channel when the file recorded does not have a time channel, but the sampling rate is known?
(3,615 Views)
Hi jingli
There is a function in DIAdem ANALYSIS to gererate time channels.
Go to DIAdem ANALYSIS, and from the first module, select the function called �Generate Data�, (second from the end).
Fill out the values accordingly and when you press execute a new channel is created that you can use to plot your Y array of data against.
Hope this helps
Tom
DIAdem Product Manager
512-683-6841
(3,615 Views)
Dear Tom:
thank you very much. I think I should explore DIAdem in detail.
thanks again.
jing
(3,615 Views)
