DIAdem
Text Data Plugin Wizard - Ignore Delimeters Inside Double Quotes
I'm trying to use the Text Data Plugin Wizard to load data from a CSV file using a comma delimiter.  Wondering how I can get the delimiters inside double quotes to be ignored.
(919 Views)
Can you share an example file with a description which delimiter is to ignore?
Holger Müller
DIAdem experience since 1996
Turn-key applications - Remote and on-site trainings - On-the-job training
| müller+krahmer GmbH | Koenitzer Straße 14, 07338 Kaulsdorf / Germany |
| Phone: +49 36733 / 2328 - 6 | Mobile: +49 160 / 287 7294 |
| Email: mueller@mueller-krahmer.de | Web: www.mueller-krahmer.de |
(897 Views)
Would like to ignore the comma delimiter inside the double quotes.
(891 Views)
Accepted by topic author danbo_16
I have only German versions of DIAdem here so I can only show a German language screenshot. If you set the parameter marked in orange (don't how it is called in the English version but literal translation would be text recognition character) to double quotes the entire section between the double quotes will be imported as one single text channel.
Holger Müller
(870 Views)
