DIAdem
TextFileReadLn returns NoValue and not Null
I'm writing this to report an issue rather than look for a solution.
The help files state that TextFileReadLn will return Null when it reaches the end of the file. However, that doesn't seem to be the case, at least not with my installation of DIAdem 2022, as it returns NoValue instead.
A minor change to my code got it working.
Regards.
(1,848 Views)
Hi Simon_Aldworth,
Thank you for your information.
DIAdem uses NaN for NoValues and indicates that the variable contains no valid data.
VBS uses Null for the same behavior. In both cases you check for NoValues or for Null with the VBS function IsNull. In the end both NoValue and Null have the same meaning.
The following script (which describes your case) works fine.
dim iHdl, sFullFileName, text
sFullFileName = "MyFullFileName.txt"
iHdl = TextFileOpen(sFullFileName, eTextFileAttributeRead)
if iHdl <> 0 then
  do
    text = TextFileReadln(iHdl)
    if not isNull(text) then
      msgbox text
    else
      TextFileClose(iHdl)
    end if
  loop until isNull(text)
end if
Greetings
Walter
(1,806 Views)
Hi Walter,
I'm afraid this doesn't work for me. My code is:
  T1 = TextFileReadLn(FileNum)
  If Not IsNull(T1) Then
    Call DataFileLoad(DataReadPath & T1)
    Etc, etc....
  End If
This fails because it enters the If...Then code and tries to load a file called "NOVALUE".
However, the following is fine:
  If T1 <> "NOVALUE" Then
    Etc, etc...
  End If
Regards.
(1,773 Views)
Accepted by Simon_Aldworth
Hi Simon_Aldworth,
Yes, the reason is T1. T1 is a DIAdem variable with the specific datatype String. A string can only contain text data and has no “marker” for NaN or Null. Therefor we implemented in case of assigning NaN (or Null) to DIAdem string variables the text “NoValue”.
In my example I used a VBS variable which is always a variant and can have different sub datatypes and works fine with NaN or Null.
Greetings
Walter
(1,769 Views)
