DIAdem
Time-domain frequency graph reverse axis
I am in the process of creating some time-frequency domain plots for signal analysis. I have plotted the frequency on the x and time on the Y (to create the right matrices). I have attached an image of how the plot looks like at the moment.
Is there a quick fix in Diadem 2018 to reverse the axis so the graph can be read from left to right?
Thank you
Andrea
(2,788 Views)
Hi Andrea,
Is this in DIAdem VIEW or REPORT? It's possible in REPORT but not VIEW.
For REPORT there are a few other forums that go through this:
how to reverse a Y-positive axis in a 2D DIADEM chart?
reverse axis
There are some limitations for what graph types this will work with (see How do I reverse a logarithmic x-axis scale in DIAdem Report?)
Hope this helps,
Rebecca
(2,750 Views)
It's for the report tab, thank you very much!
(2,745 Views)
Accepted by Andrea12345
Hi Andrea12345,
Have you looked at the following tutorial/application?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x14vCAA&l=en-US
Brad Turpin
(2,738 Views)
