DIAdem
Trying to plot 3D contour plots with time formatting error!!!
I plot time, mass flow, and fuel rate on a 3D axis system with grid in all planes and the 3D Curve line type it defaults is ok, but I need to see this in a 3D contour plot which is actually called a Characteristic Diagram in DIAdem. When I select this, it tries to plot in 3D Contour, but returns the following error.."Discrepancy between time format in axis layout and header of channel." My excel file the data comes from in in format hh:mm:ss:xxx and I cant figure out why DIAdem wont recognize this and plot. Please help.
(3,353 Views)
Hello BajaBoy,
I think it would be easiest to figure this out if I had the data to look at. If you can send this too me (I will treat this confidientially and it will be deleted after we got it to plot) please sned to me me directly at National Instruments.
My email address is my:   first name DOT last name AT ni DOT com       (no middle initial!).
We'll get back to you with an answer the same day unless we run into the Thanksgiving holiday before we get this.
Hope that helps,
Otmar D. Foehner
(3,328 Views)
