DIAdem
USI error when loading TDMS file
A Labview project is generataing TDMS files, on my computer the TDMS files are opended correctly in Excel.
While on other computers the users receives the following error: "Warning: The datatype of the channel 'NAME OF CHANNEL' is not supported by USI!"
This results in that when viewed in Excel, the channels contains 0 data. When I try to open the same file on my computer I get all the data.
(5,684 Views)
Accepted by topic author cdonc
Do you have the latest version of excel addins installed on the other machines?
http://zone.ni.com/devzone/cda/epd/p/id/2944
Which DIAdem/USI version are you using (DIAdem about box) and is NI Software installed on the other machines.
(5,676 Views)
The issue was fixed by updating to DIAdem 2012
(5,644 Views)
