DIAdem
Undo Sheet Deletion Bug (DIAdem 2014 SP1)
I am experiencing a bug in the Report section of DIAdem.
I have ~80 sheets in a report.  I delete the last one by right clicking and selecting "Delete".  I confirm the deletion when prompted and the sheet goes away.  I now press Ctrl-Z to undo the deletion.  DIAdem appears to reload the whole set of 80 sheets and the sheet that I deleted is back.  The undo function works.
The problem I have now is that I lose the mouse input for the report section and data portal.  I am able to change the view to NAVIGATOR, VIEW, etc. with the mouse but I can't click on anything else including the pull-down menus.  Keyboard navigation works as I can move around the report and edit Text blocks, etc. but the mouse input is completely gone.
I am using DIAdem 2014 SP1.  Can anyone replicate this issue?
Jacob
(4,555 Views)
Hi Jacob,
Could you export your DIAdem reports as a .TDR file so we can try it out on another system and see if the problem is reproducable?
(4,528 Views)
