DIAdem
Upon computer startup: "Attempted to start multiple instances of the service"
Recently installed Diadem and there must be some sort of registry error.  Whenever I startup I get the error "Attempted to start multiple instances of the service" anyone know the registry fix for this? Thanks!
(4,280 Views)
Hey Kyle,
Check your services and see what’s running.  This can be done by going to Start>>Run and type “services.msc”.   Then look for anything that starts with National Instruments or NI.  Look to see if there are any entries running twice or if you are trying to call a service that is already running.
Nick
(4,265 Views)
Hi Kyle,
This doesn't sound like a DIAdem-specific error, and I've certainly never seen it before.  What other NI software do you have installed on that computer?
Brad Turpin
DIAdem Product Support Engineer
(4,261 Views)
My apologies, I fell into a hole apparently.  I had Labiew on my computer and deleted the program previous to installing Diadem.  I used msiblast and followed the instructions on the forum when removing Labview.  Thanks!
(3,974 Views)
