DIAdem
"My DataFinder" is missing
The standard profile "My DataFinder" is missing. When I start Diadem I get the error message "Fehler:Der Datenbestand "My DataFinder" ist unbekannt."
The DataFinder dialog is empty and also the menu for the Data Finder options are grey and not active, except "Zurücksetzen" (reset), which does not work.
I also tried to setup a new DataFinder called My DataFinder, but this is only possible for a remote finder. But I also got the error message, that this profile is already existing.
The DataFinder task is working and it is shown in the taskbar.
Thank you for your response.
(4,380 Views)
Hi lkl,
please go to
<Documents and Settings>\All Users\Application Data\\National Instruments\Shared\USI\Config
and rename the file
storetypes.usiconfig
Now start DIAdem again.
Hope this helps
Stefan
(4,376 Views)
unfortunately there is no difference. I also copied the file from another installation, which works fine regarding the My Data Finder profile, but that didn´t work also.
(4,372 Views)
If the rename of the storetypes.usiconfig in <Documents and Settings>\All Users\Application Data\\National Instruments\Shared\USI\Config not works. Please rename the storedefinitions.usiconfig and launch DIAdem again. Make sure DIAdem is completely closed when you rename the file.
Regards
Thomas
(4,339 Views)
