DIAdem
Use of CreateTime - missing millseconds .....
Hi Brad,
Thanks to you and Andreas, I am able to have my time data in a time channel.  My problems start when I want to use that data.  I find that I cannot just read milliseconds or smaller like with a property.  This script works for me: -
Dim oTime
dim TimeObj
Set TimeObj = CreateTime(2004,6,17,10,20,30,900,500,9)
Data.Root.Properties.Add "Hope", TimeObj
Call MsgBoxDisp("Microsecond: " & TimeObj.year)
Set oTime = Data.Root.Properties("Hope").oValue
call MsgBox(oTime.nanosecond)
but I cannot get an 'equivalent' script that allows me to read values from a channel.  For example, this script returns a false value for milliseconds:-
data.Root.Clear
dim chTime
set chTime = data.root.ChannelGroups.Add("group").Channels.Add("Time",DataTypeChnDate)
chTime.Values(1) = createTime(2017,6,6,10,23,45,800)
MsgBox chTime.oValues(1).Millisecond
It returns 500 for any input (in CreateTime) > 500...
I would like to be able to use Time channels just like I do numeric or text channels, but I can't even read and write values.  I am missing something fundamental in my understanding about how it should work, but I don't know what.  Why for instance, do I get a value of 500 instead of 800 ms for the script above?
Again, Thanks for the help and patience,
Thomas
Message 11 of 14
(977 Views)
Because DIAdem Time channel is internally represented by a double I would create seperate channels for
milli and nanoseconds. The resolution of a time channel is reached at this point.
An alternative is storing the start time in a property and using a float64 channel storing the offset to the start time.
I am sorry but there is no easy solution at the moment if you need high precission.
Message 12 of 14
(962 Views)
Hi Thomas,
When I copy and paste your 5 line script into my DIAdems, here are the results I get:
DIAdem 2015 SP2 32bit .... returns 500
DIAdem 2015 SP2 64bit .... returns 800
DIAdem 2017 SP2 64bit .... returns 800
This suggests to me that there is a bug in DIAdem 2015 32bit.  Do you have the option of installing the 64bit version instead?
Brad Turpin
Message 13 of 14
(951 Views)
I tested with DIAdem 2010 32bit and I could reproduce the behavior you describe.
It is fixed in all newer versions.
However if you can not upgrade there is a workaround
Option Explicit
data.Root.Clear
dim chTime
dim timeVal : set timeVal = createTime(2017,6,6,10,23,45,800,600)
chTime.Values(1) = timeVal
' call woraround method
dim millisecond, Microsecond
call GetTimeFraction(chTime.Values(1), millisecond, Microsecond)
MsgBox millisecond & " - " & Microsecond & VBCRLF &_
       chTime.oValues(1).millisecond & " - " & chTime.oValues(1).Microsecond
sub GetTimeFraction(byVal timeVal, byref milliSecond, byRef Microsecond)
  ' does not work in DIAdem 2012
  'milliSecond = diaChn.oValues(index).millisecond
  'Microsecond = diaChn.oValues(index).Nanosecond
  ' workaround using R1 double value with direct double access
  R1 = timeVal
  dim fraction : fraction = R1 - fix(R1)
  fraction = fraction * 1000
  milliSecond = fix(fraction) ' fix part of double contains milliseconds
  fraction = fraction - milliSecond ' remove fix part
  fraction = fraction * 1000 ' now fix part contains mi
  Microsecond = fix(fraction)
end Sub
using an explicit cast of the channel value to 'R1' which is a build in variable.
GetTimeFraction
just makes use of this and calculates the fractions by double arithmetic.
P.S.: This will also work in future DIAdem version. So a script including it will not break on upgrade
Message 14 of 14
(933 Views)
