DIAdem
Using VariantVarSet with OLE
Hi -
I am trying to play around with DIAdem OLE commands and I am using Visual Basic...
Here is my code segment...
    Me.MousePointer = vbHourglass
    ' Initialize TOCommand Interface:
    Set oDIAdem = CreateObject("diadem.tocommand")
    strNew = txtVarValue.Text
    lSuccess = oDIAdem.VariantVarSet("BjmTestVar", strNew)
    lSuccess = oDIAdem.VariantVarGet("BjmTestVar", strNew)
    txtRetValue.Text = strNew
    Set oDIAdem = Nothing
    Me.MousePointer = vbNormal
The problem is that the variable gets cleared when I execute the VariantVarSet command.   I can have a value in the variable "BjmTestVar", and can get it with the VariantVarGet command, but when I use the set command the contents get cleared.   I can not get a value to be stored with the VariantVarSet...
Any pointers and/or suggestions?
Thanks for any assistance or information!
Bruce McPhee
EDS - An HP Company
(3,617 Views)
Hi Bruce,
I haven't used the VariantVarSet method myself, but in general in DIAdem you would need to create the global variant variable with the "GlobalDim" command before you could address it.  Alternatively, you could use one of the already pre-allocated variant temporary variables:
oDIAdem.VariantVarSet("O1", vVariant)
Brad Turpin
DIAdem Product Support Engineer
Mational Instruments
(3,601 Views)
