DIAdem
Using boolean variable with Select Case
I have setup a dialogue box with two radio buttons and allocated B1 as a variable for it, having a value of either 0 or 1 depending on the choice of radio button.
I then use Select Case to examine the value of B1 and find that Case 0 and Case 1 doesn't work, but Case False and Case True does. My code is:
B1=1
Call SUDDefLoad(AutoDrvUser&"Actions.sud")
Call SUDDlgShow("Analysis")
if DlgState = "IDOk" then Select Case B1 Case False Call ScriptStart("GetData") Case True Call ScriptStart("GetContData") End Select else Flag = 0 Call Err.Raise (-1) 'Autoquit end if
A similar dialogue box written by a colleague uses the same concept for the radio buttons and variable, but his code works because he uses an If statement to determine the value of B1. His code is:
B1=0
Call SUDDlgShow("Decimate")
if DlgState <> "IDOk" then
end if
If B1=0 Then
  NoPts = Val(T1)
Else
  NoPts = L2/Val(T1)
End If
Why the difference in behaviour with the use of B1?
Simon.
(3,364 Views)
Accepted by Simon_Aldworth
would it ever be true?
(3,347 Views)
The confusion deepens. You seem to have proved that B1 cannot use 0 or 1, and must use True or False instead.
I tested my colleague's code and it seems you are correct. His code only worked because he used "If B1=0" and "Else", which is the only case that turns out true in your experiment!! I have changed his code to use True and False.
However, the DIAdem help files state that a Boolean variable type can take the values TRUEFALSE or "YES", "NO" or 10. See here for example in 2018 online help. Not at all helpful!!
Simon.
(3,334 Views)
The docs are fooling us... the only "truthy" value i found was -1
(3,331 Views)
