DIAdem
Using channel values in a Report text box
Yes, I'm afraid I still get the same error messages when trying this exact line of code. As you say, I can only assume that later versions allow this code to be used without throwing errors.
Thanks for trying.
Regards.
Message 11 of 13
(822 Views)
Accepted by Simon_Aldworth
Hello Simon,
Just to follow up: I tested the code lines from above on an old DIAdem 11.3.0 installation, this was the result:
Then tried DIAdem 14.0.7, same result:
Trying DIAdem 15.0.2 ("2015 SP2"), the error popup does not show up anymore:
Looks like the behavior was changed between DIAdem 2014 and 2015 SP2, so that's the version you are aiming for, at least.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 12 of 13
(812 Views)
That's very helpful - thank you very much.
Simon.
Message 13 of 13
(807 Views)
