DIAdem
WINHelpCall is not working properly why?
I have created a .chm file for help so when i tried to use WINHelpCall function of DIAdem to popup the help with required contents it is not giving proper result why?
(3,423 Views)
Hi abc421,
The WinHelpCall command in DIAdem is a wrapper for the Windows API call WinHelp(). This API call was designed for the older Windows Help format (.HLP files). You CAN use the following to display a .CHM file (but not the specific topic):
WinHelpCall "calc.chm", "WINHelpPartKey", "statistics"
WinHelpCall "calc.chm", "WINHelpIndex"
The .CHM files are designed to be used with a different Windows API function (HtmlHelp(), which DIAdem does not have a wrapper for yet). However, you can use this syntax in a DIAdem VBScript to open a .CHM file:
ExtProgram "hh.exe", "mk:@MSITStore:/path/filename.chm::/path\topicname.htm"
Here's an example that opens up the Windows Calculator helpfile directly to the "To perform a statistical calculation" topic:
ExtProgram "hh.exe", "mk:@MSITStore:calc.chm::/calc_statistics.htm"
If you have further questions please consult Microsoft's documentation for HH.EXE.
Thanks for contacting National Instruments!
David Mc.
Applications Engineering
(3,423 Views)
